Hi all,
Since everyone here was so helpful with my other query regarding NTSC to PAL conversion, I thought I'd try another question in here
My problem is with the quality of MPEG files produced by TMPGEnc using the VideoCD template.
I am capturing from a VHS tape, or direct off-air TV picture, to DV AVI using Premiere. The DV file is beautiful quality - no problem there. MPEG2 quality from TMPGEnc is also beautiful quality - no problem there either.
The problems start with MPEG1, using the VCD template. All the motion is extremely blurry - as soon as anything moves in the image, it's like a smoke-screen appears in front of it, until it stops moving again. The result is unwatchably terrible. MUCH worse than a VHS recording!
I have tried upping the motion search precision to maximum quality, but there are so many options in TMPGEnc that I simply don't understand, I wonder if there's some other setting I need to change to sort this out?
Thanks in advance for any tips!
I am having much the same problem. My problem is extreme blockiness on high motion video.
However, the next method I'm going to try is increasing the bitrate on the VCD. This method is explained at the BBS in TMPGEnc's website (copy from another post):
1. First start tmpgenc, then load your avi file, then click the "LOAD" tab in the bottom right corner then LOAD the "unlock.mcf" template then all the settings will be unlocked, this is how you load templates , there should be 2 folders full of templates with different setting and differant names like "vcd ntsc" and "vcd ntsc film" and "svcd ntsc" and "svcd pal" ect,ect, you load a template for what you want to do, so you want to make a "ntsc vcd" but you want to use a higher bitrate, so you load the "ntsc vcd template" then you load the "unloac.mcf" template so you can raise the bitrate.
2. raise the bitrate of your vcd ,if you raise the bitrate of your vcd to about 1650kbs you will get about 60 minutes of video per cd, with much better quality than the standard template..
Let me know if this works for you, hopefully it will work for me when I get a chance to implement.
Good luck.
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Poor Video Quality
By itsernst in forum Capturing and VCRReplies: 20Last Post: 10th Feb 2010, 16:32 -
Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic's
By drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 08:37 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 16:37
