Hi,
I want to buy DVD recorder and I´m thinking to buy Pioneer A04. Is it the right solution? Can this DVD recorder burn double sided DVD´s and if it can, how? How can I set the point in the video when the video has to continue on second layer (because there is 1 second pause between layers)?
Thanks...
I think perhaps you're not entirely clear on the concept, here.
The double-sided DVD-R blanks you see for sale are not "dual-layer" discs. They are literally double-sided - i.e. you have to physically take the disc out of the drawer and flip it over to record (or play) the second side. There is currently no such thing as a dual-layer DVD-R recorder, nor a dual-layer blank disc... and honestly, I wouldn't expect to see such a beast any time soon. (I can't even conceive of how it would be possible, frankly - though that doesn't mean someone won't find a way to do it.
So, the answer to your question is: when making your MPEG files in the video editor/encoding program of your choice, you find a good spot about halfway through the video and encode everything up to that point as "Side_One.MPG", and everything after it as "Side_Two.MPG". (How, exactly, you do this is left as an exercise to the reader, since I don't know what software you'll be using.) Then, you use your DVD burning program to burn "Side_One.MPG" onto the first side of the DVD-R blank, then flip the blank over and burn "Side_Two.MPG" onto the second side.
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 13:52 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 16:47 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 20:23 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 09:09 -
pioneer dv 470 and double layer discs
By SquireC in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Dec 2007, 05:09
