I first created the audio wav file for the movie using virtualdub. I then used TMPG to encode the SVCD movie. I then used VCDEasy to create the SVCD image. When Creating the image the "non-MPEG1 audio stream header seen" error occurs numerous times in the log. I then burn the SVCD using fireburner. When I play the SVCD in my player, the video is fine but the audio Cuts in and out about every 1/4 of a second. When I fast forward the video with audio on, the audio sounds fine. Any Suggestions?
Results 1 to 1 of 1
Critical Error (Event ID 41 Kernel-Power) causing win7 BSOD & reboots
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 28th Mar 2012, 16:19 -
why is tsmuxer making my stream bigger?
By maca in forum Authoring (Blu-ray)Replies: 3Last Post: 3rd Jan 2012, 17:11 -
MKV stream extraction causing audio sync problems
By PlanetIndigo in forum Video ConversionReplies: 18Last Post: 29th May 2011, 23:07 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 15:33 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00
