i had probs capturing with movie maker and encoding to dv avi for dvd burn,a friend said try capturing with premiere straight to file in avi. i set it up with different templates the only way i could get it to work without problems is to use the video for windows preset 640x480 0r 720x480, i captured like 5 mins with my vcr going to my tvwonder ve card and it looked great!
feeling great i popped in a tape (1 hour) and let her capture, says not a frame lost looked to be no probs saved it to file about 9 gigs i think. so i try to open it with every program i can imagine and it says its unsupported or corrupted! if i capture using same settings for like 5 mins or so its just great?!!
do i have a setting wrong? should i capture with virtuadub and screw premiere? if so can someone mail me a brief virtuadub capture how to?
thanx specs and email are in my profile
premiere will only capture a max 2gig avi with that setting ..
use AVI_IO instead ...
what happened is that up to 2gig everything is fine but over that it is screwed ...
yes - i know NTFS will allow a larger avi -- but it is premiere thats the problem.
what capture compression were you using anyway ? -
where do i get the io? in tools? and my card says it captures in mpeg 2. i used to capture with win xp movie maker then encode to dv avi but that goes way out of synnch after 15 - 20 mins can you give me a little better insight into the program where to find and how to use thanx for your help
i dloaded avi io and ill try it tonight any tips to save me some hair pullin? think my simple dvd maker will recognize its files?thanx
Any Kworld Capture Card Users: Help!
By rind1984 in forum Capturing and VCRReplies: 5Last Post: 3rd May 2009, 22:50 -
After Effects or Premier
By milway in forum Authoring (DVD)Replies: 6Last Post: 17th May 2008, 16:16 -
M2TS to Premier
By Mylriahd in forum Video ConversionReplies: 24Last Post: 6th Mar 2008, 11:17 -
Premier Elements 4 and codecs ?
By holeepassion in forum EditingReplies: 0Last Post: 1st Feb 2008, 04:08 -
Premier Elements help
By didikai in forum Newbie / General discussionsReplies: 7Last Post: 27th Aug 2007, 03:54
