hi, i loaded an AVI into VirtualDub and got this msg "VirtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 16040 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder (bitrate: 143.6 = 16.0 kbps)"
what is the best thing to do?
thanks
