i ahve got to seperate about twenty audio tracks from a huge wav file i recorded off a cassette tape. i need to save the files individually and add them back into a videotime line later. I use premiere-can this be done in premiere? how? simple is the key. thanks again--another last minute project for mike
Do a search for wave file editors or wave file splitter or something like that in http://www.download.com. You should be able to find something there.
I use Premiere all of the time for anything and everything video. There couldn't be a better solution for you, because of Premiere's Timeline, you can do all of this in one session of the program, and fairly quickly. Premiere will let you seperate the audio tracks with the razor tool with frame accuracy. Then you can export each individual slice that you have created as a seperate file, which you can then import later on in future Premiere projects. If you need specifics on how to do this, visit me on IRC, or email me.
irc.webmaster.com port 6667 #DDR
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 20:32 -
Editing audio attached to video
By NALLEN121 in forum AudioReplies: 1Last Post: 20th Oct 2011, 14:25 -
Editing HD video with E-AC-3 audio codec?
By calande in forum EditingReplies: 0Last Post: 23rd Jul 2011, 07:36 -
Audio problems when using video editing software
By luckydoll in forum AudioReplies: 2Last Post: 16th Jul 2010, 22:08 -
video and audio editing software
By limazita in forum MacReplies: 1Last Post: 10th Mar 2009, 08:26
