Hi All,
I just bought a Fiji Finepix S602 Digital Camera, which records movies in .avi format, at 640x480 at 30fps with sound. Copy the files onto my PC, great, I can watch them in windows medi player.
However herin lies the problem.
I mostly film my new 14 week old daughter, and want to create SVCDs which I can send to friends and family so they can see how shes growing etc. I have tried opening these files in Adobe Premier 6 and TMPGenc and neither of them can open the file. Can anyone please offer me any advice as it would be much appreciated.
Glen![]()
Hi All,
Ive looked at file properties, and it said unknown video codec, but Morgan Stream Switcher for Audio. Does this help? -
If you can load them into Virtual Dub, you can frameserve them into TMPGEnc.
Hello. -
Hi,
Ive downloaded Virtualdub, and it plays fine in this program.
Im a newbie to this, so is there any chance of an explanation of what to do to get this into a decent format ready for SVCD?
Thanks in advance
Glen -
You're halfway home. Set up VDub to frameserve, Load TMPGEnc, select the Super VCD Template with the Load function, name your output file, and the resulting file of your little princess is ready for the SVCD burn. You only have thirty days to use this SVCD template because mpeg-2 is disabled after then. Here is the framserve guide:
http://www.vcdhelp.com/convert.htm#frameserveHello. -
Hi TommyKnocker,
Thanks for your help - I now have a useable SVCD ready MPG!
There's nothing better than staring at these menu's feeling very very stupid!
Oh, my daughter, Molly thanks you too! (well actually it was more of a gurggle, but hey!
Better think about buying that software now then...........
Thanks again
Glen
Boxee Box issue ... need to convert DV AVI to H264
By njitgrad in forum Video ConversionReplies: 20Last Post: 27th Feb 2011, 14:40 -
convert issue
By gow75 in forum Video ConversionReplies: 3Last Post: 1st Apr 2009, 19:19 -
Convert Iron Man BD to MP4 using RipBot - Audio Channel Issue
By csilvest in forum Blu-ray RippingReplies: 5Last Post: 27th Jan 2009, 11:25 -
wierd playback issue in MPC
By fix25 in forum Software PlayingReplies: 0Last Post: 26th Oct 2008, 17:03 -
.VOB to PSP-Movie issue. Certain won't convert
By egmadayag in forum MacReplies: 5Last Post: 23rd Oct 2007, 16:14
