I've read some of the newbie faqs, but I'm still confused.
I want to capture cartoons and put them on CD's for my little girl to watch on her DVD player and 13" TV.
I have ATI AIW 7500 in Dell 2 gighz machine, and a Samsung DVD S221 player. The player says it supports CD, CD-RW, etc.
I tried a simple capture and copied it to a CD. The player didn't recognize it.
When I capture with the ATI, I am capturing in VCD format in the ATI software (352x240).
Can someone get me on track here?
Guest
The DVD player might not be able to read vcd. How old is it? Do you know the make & model? If so, check to the right column, under "other".. the DVD category will let you conduct a search. I've heard if they can read mp3s, then they should be able to read other mpegs but I read that in a newsgroup like this one.... so you never know! Best of luck =)
Heidi -
Did you just copy the file to the cd or did you author it with a program like Nero? VCD's require a specific file structure and must be authored by a program that creates vcd's.
If you knew this already, forgive my blather...
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 17:00 -
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 09:49 -
Simple question about video capture from ps3
By adamsbomb in forum Newbie / General discussionsReplies: 0Last Post: 11th Mar 2010, 01:48 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 14:12
