hi iam a newbie,iam using ulead vs to capture and edit my video from sony dv camcorder,i want to add some transition effects using ulead vs but i want to encode it with tmpgenc to make a good quality cd how to do this, pls help me
Your question sounds a little vague. I use transition in Ulead VS by going to the Storyboard, dropping each video segment on the time line.
Then, when the segments all are in the time line, I go to the Effects tab and choose the transition I like (that 3D Flying Cube is just too cool). I drop it between the segments I want the transition to take place at. I then stretch each transition to around five seconds or so, to give the viewer a chance to see how cool it is.
Once all is inserted, I select the Finish tab, select Create Movie File, choose the name of my movie, and let VS make the movie file. You can then use TMPGEnc to convert this file to your format you want for your CD.
Did I answer your question well enough?Hello. -
Basically in any decent editor output the movie to a lossless or near lossless AVI file then use TMPGenc to convert to MPEG.
Panasonic DMR-ES45VS, keep those discs a burnin' -
crajshree,
Just chose make a video file and keep it in DV format from VideoStudio. Then compress the DV file with TMPGENc. -
Well, TMPGEnc encodes, but I suppose you could also say that it has compressed the file due to the fact that the resultant mpeg(vcd) file is much smaller than the DV avi file.
Craig
Does reauthoring (TMPGEnc DVD Author) re-encode / degrade video quality?
By MheAd in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2010, 05:42 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Help encode permanent subtitles and then edit DVD
By kapital in forum Newbie / General discussionsReplies: 11Last Post: 29th Apr 2008, 09:43 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 14:07 -
TMPGEnc DVD Author - Does it re-encode DVD Video?
By bbanderic in forum Authoring (DVD)Replies: 2Last Post: 21st Oct 2007, 12:58
