Hi
I am having a bit of trouble with a SVCD.
I am trying to extract the mpg from the CD to convert to VCD in TMPgenc (to reduce no of CDs)
This is nothing I haven't done many times before but for some reason I can't extract the mpg using isobuster all I get is a file that is recognised as music in media player.
I have also tried CDmage with no luck.
Any suggestion please
Flash
Are you saying you have a ISO of a SVCD disk ? or the SVCD disk ?am trying to extract the mpg from the CD to convert to VCD in TMPgenc (to reduce no of CDs)
I have the SVCD disc on CDR. It plays okay in my DVD player (Yelo800) but that plays anything.
Flash -
Ok, well the file will load into TMPGENc without convertion, as long as you have the mpeg 2 codec.
Nimo for free copy
PowerDVD 4, for TMPGENc Plus.
Where does the ISO buster come into it ?
If it won;t work...try dvd2avi and open the mpeg, convert to avi, then to MPEG.
Is a hure way around...but tmpg should do the job. -
I already have Nemo codec pack installed and isobuster I use to extract the mpeg from the dat file in the SVCD CD.
Google Busting Hollywood's Balls
By budwzr in forum Off topicReplies: 1Last Post: 14th Nov 2011, 20:43 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 17:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
