I've ripped a DVD to my hard drive, but when I try to convert (MPEG4 or any other compression -- same result uncompressed), I get motion lines whenever something moves too quickly. I ripped using SmartRipper, and I'm converting using FlaskMPEG. The size is the same (720 x 480), and the framerate is unchanged (NTFS at 29,97). I used a 910 k/s rate (didn't seem to change anything when I raised it to 1200).
I've managed to reduce the problem by changing the Flask video settings to 'Deinterlace video' (with a threshold of 5 -- seems to work better than 20). Also placed a checkmark in 'Blend instead of interpolate' (not sure what this does). But I still get horizontal lines in large surface colors that move quickly. Anyone know how to fix this, or suggest something other than Flask to convert to Mpeg4/Divx?
Results 1 to 1 of 1
Problem with motion getting jagged lines
By philflo in forum Video ConversionReplies: 2Last Post: 6th Mar 2012, 09:27 -
How do you avoid motion lines in your ripped DVD file?
By metrosuperstar in forum DVD RippingReplies: 39Last Post: 18th Sep 2010, 17:04 -
Problems with "Motion Lines" in SOME ISO to AVI conversions using
By cplevel42 in forum DVD RippingReplies: 8Last Post: 8th Oct 2009, 18:30 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 20:59 -
I recoded my VOBs to AVIs, now I have like 'motion lines' thru the video??
By lrfowler in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2007, 20:43
