Hello all,
I noticed a strange behaviour with my LG 16 x drive and it's causing a lot of problems ;( .
When I'm ripping a DVD to an image ( Nero ) usually I get something like 10M/12Mbytes per second to the hard disk, but when by some reason the drive encounters a reading problem ( scratches , dust , etc ) it stops instead of reducing the speed and try again! But even more strange is that Nero continues to read ( like there isn't any problem ) and the DVD it's not running. I assume that the Nero is getting the data from buffer because the ripping speed becomes higher ( 20/22 Mbytes per second )!
What I would like to know is :
What's wrong ? Drive LG DVD 16x ? Nero 5.5.9.0 ?? Via IDE bus ? Or all of them ?
Any help? Please?
Thanks,
FJorgeR
PS: I tried to lower the DMA setting to ULTRA DMA mode 1 and finally Multi read DMA mode 2 ( lower speed extraction 7/8Mbytes per second ), and the same problem occur ;( .
Are you attempting to burn an image direct from the original DVD ?
If so - I don't think you can do this as the CSS encrypion on the DVD will stop you copying it peoperly (even to an image file). I think the copy starts because the menu's, corp logo's etc are not usually encypted.
To produce a DVD copy, you need to follow one of the DVD copying guides listed in this site - but in summary - rip (deCSS), author, reMPeg if bigger than 4.3Gb and then burn with Nero... -
Originally Posted by TeeeRex
Well , sorry but my post shoudn't be here ;(
I'm trying to backup a regular DVD ( data ) not DVD movie !!
Regards,
FJorgeR -
I think probably not, because these forums are all about movies/video etc.
MiniDvd Ripping Issue Nero 10
By OnThreeGo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Dec 2010, 12:00 -
Rescue JVC DR-MH20SE harddisk
By Anamon in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Aug 2010, 16:29 -
How do I copy the files on my (HD)DVD / Blu-Ray disc to my harddisk?
By c018279 in forum Blu-ray RippingReplies: 3Last Post: 14th Nov 2008, 00:42 -
Panasonic E95H Harddisk unformat
By Flyrider in forum DVD & Blu-ray RecordersReplies: 2Last Post: 1st Sep 2008, 17:46 -
I'm looking for a multimedia harddisk
By andyr74 in forum Media Center PC / MediaCentersReplies: 9Last Post: 30th Apr 2008, 12:16
