I have Pinnacle DV500 capture card and Sony PC155 comcoder. When I try to download the casette to my PC, it generates huge size files such as 1GB for a 5 minutes video. The generated format is AVI. I know, however that, the camcoder uses DV-encoding.
Is there a way to download encoded video from camcoder to PC while generating smaller file sizes? (I use Pinnacles' software to download to PC, is there a better software for this?)
No it is not possible, DV is a constant size...some DV cards support hardware compression to mpeg2/mpeg1 but I don't think yours does. And compress is not that good if you would like to edit and add filters. Get a huge harddrive instead...they are very cheap.
It is possible to use software real time mpeg encoders. Programs such as Ulead DMF or Dazzle DVD complete have such optional settings. However, these options are better left off as they yield lesser quality results. You are better off transfering to your hard drive the temporary avi (DV) file, encoding to mpeg and then deleting the avi (DV) file.
Convert SONY CAMCODER PAL to NTSC
By bkdomrep in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 26th Sep 2013, 15:05 -
Novice needs advice on buying an HD Camcoder.
By gott in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 4th Sep 2010, 16:07 -
Looking for a small digital camcoder around £120
By Killer3737 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Oct 2009, 14:54 -
Fixing Camcoder DVD
By EdwRom in forum Newbie / General discussionsReplies: 17Last Post: 6th Sep 2008, 08:36 -
Format for archiving camcoder video?
By Arctirus in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2008, 22:54
