in the link below
http://www.vcdhelp.com/dazzlecapture.htm
it says something about -
"Also their is a "high quality" box just under the 3 settings-- make sure you check this off to give it that extra boost for your picture. AND make sure the "enable filter" box is checked as well"
when it said make sure you check this off for the "high quality box"
does he mean to check the box or just to leave the box
thanks a lot for the help
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 22:14 -
Video: noise reduction filter for MPC
By bonanza in forum Software PlayingReplies: 1Last Post: 9th May 2008, 12:18 -
Chroma Noise Reduction filter for Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 10:43 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 07:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 20:22
