I have the problem of TMPEnc not supporting my MPEG-2 capture files, so after researching this site and many of the forums, I downloaded and tried to install the Nimo codec Pack. For some reason, it is not installing any MPEG-2 codecs.
After installing, I look in Control Panel -> Multimedia -> Devices -> Video Compression Devices, and nothing is there relating to MPEG-2, even though I selected it in the Nimo install routine.
What am I doing wrong.
I also tried the Elecard MPEG decoder and it is never installed either.
Am I looking in the wrong place? If the TMPGEnc free version works fine for me, then I have no problem paying the $50 for the real version, but I want the trial to work first before I pay for it.
Ok, Nimo does provide Mpeg 2 for older versions, 2.55 I think, but if you use TMPGEnc Plus 2.57, then those codec's are no use, instead you will need to install Power DVD 4, that is 1 of 3 codec's that will work with the new version.
Use an older Free TMPGEnc -
i have powerDVD 4.0 ,LSX-MPEG from ligos and some others but
MPGENC 2.57 worked only when i installed the nimo codec pack.
previews version 2.56 worked with elecards MPEG2 player,but 2.57 didn`t
what version of nimo you try to install?mine is Nimo50Build7 -
The Nimo version is the latest, version 5 build 7 I think.
I'll see if I can find an earlier version of TMGPEnc and try it. -
Sometimes you have to remove one for the other to work, if you intend using the Free TMPGENc 2.55 then Nimo is just fine ( for 30 days ), but if you move on to TMPGENc Plus, you need to remove other Mpeg 2 codecs before you install Power DVD
I would remove them if they existed. I think this is the problem. When I install Nimo, no MPEG-2 codecs are installed. I've tried this at least 5 times, but no MPEG-2 codecs ever appear in my Control Panel.
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 05:34 -
Programme won't install
By DuBsTaR in forum ComputerReplies: 2Last Post: 18th Nov 2007, 10:06 -
Linux won't install
By lordsmurf in forum LinuxReplies: 1Last Post: 13th Aug 2007, 11:59 -
XP won't install 56k modem
By zanos in forum ComputerReplies: 7Last Post: 5th Jul 2007, 21:25 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:01
