ATI's MMC 7.1 works perfectly. Whenever I try to use another capture App such as freevcr or virtualdub I get a box saying that the capture device is already in use and I must close down other apps such as Web TV etc... before I can continue. There is nothing else apart from Norton Antivirus and Direct CD running in the background and Web TV isn't even installed. Whats going on??![]()
I to have had this problem. The way I get rid of it is to shutdown the ATI Launch Pad, and close all windows. Then I restart Virtualdub and it seems to work.
Is there any software that lets you edit 1920 and do green screen or roto
By Onceler2 in forum EditingReplies: 7Last Post: 2nd Oct 2011, 05:08 -
FLV Input Plugin for Virtualdub lets you save as AVI with no quality loss?
By gumbygum in forum Video ConversionReplies: 7Last Post: 1st Aug 2010, 15:08 -
What's a good program that lets you choose end file size for AVI?
By THRobinson in forum Video ConversionReplies: 6Last Post: 5th Apr 2010, 21:42 -
what freeware editor lets you edit left and right portions of your wav
By Onceler2 in forum AudioReplies: 15Last Post: 11th Jan 2009, 09:46 -
LP player that lets you record to computer
By Tearren in forum Off topicReplies: 3Last Post: 30th Dec 2007, 05:40
