Results 1 to 9 of 9
  1. Has anyone gotten the Panasonic Mpeg Encoder Plug In to work with Flask? I have tried many times and renamed it exactly as people state but it never show up. Any help would be appreciated. Thanks.
    Catman
    Austria
    Try DVDx with the pansonoc plugin and it works great.
    You dont need to rename it for DVDx.
    The best DVDx version is 1.7 it has the best resizing routines, DVDx2.0 is only good for speed but not for quality.
    AMD XP2000,ASUSA7V333.GF3 V8200 TI200,
    Alpha 8045,Y.S Tec Poer Fan, Seagate Baracuda IV
  3. Thanks, I will give it a try.
    Catman
    Aug 2002
    cohoes,ny
    where can i get the panasonic plugin i use dvdx2.0 i have 1.7,1.8,2.0
    Epox-8k7a
    amd xp1900+
    gf3
    16xdvd
    32xcd-rw
    2-40gig maxtor drives
    21" digital monitor
    ati tv wonder pci
    win 98se
    Austria
    http://www.networkserve.co.jp/mpeg/index_e.html
    but it is a demo version, and will only encode 30 sec of video, but its long enough to see,some quality differences.
    Aug 2002
    cohoes,ny
    thanks Jaspa i have a non-demo version how do i use it with dvdx ???
    Epox-8k7a
    amd xp1900+
    gf3
    16xdvd
    32xcd-rw
    21" digital monitor
    ati tv wonder pci
    win 98se
    Austria
    You must only, install the panasonic encoder in the same directory where DVDx is.
    Then load the plugin ,in the outputsettings fron DVDx.
    That was it
  8. Um, I've got the Panasonic encoder plugin and it works just fine with Flask...
    If you don't have Adobe Premiere installed, you will need to create a "dummy" Adobe plug-in directory for the installer.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Aug 2002
    cohoes,ny
    i have adobe premiere also . thanks
    Epox-8k7a
    amd xp1900+
    gf3
    16xdvd
    32xcd-rw
    21" digital monitor
    ati tv wonder pci
    win 98se
