Hi
Is it possible to get my a04 to burn with spruceup.
If so what do i have to do.
If not what is the problem why it wont.
dave king
just use spruceups burn title set option instead of burning it directly with spruceup, all you have to do is burn the video_ts and audio_ts folders with either prassi nero or discjuggler and youll have a working dvd no need to burn directly with spruceup need more info check out the faq in the author section good luck
here to help or express myself not to rack up my posts
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 05:10 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
