This is my first post so please understand if this topic should be elsewhere, i've checked FAQ and some history of posts on this site but despite some related issues i carn't see the problem listed anywhere the way that i'm experiencing it.
First off i'm working with Windows XP, using Nero 5.582 to burn VCD's and playing back on Power DVD4.
Now i've read the tutorial here about burning simple menus with Nero, no problems following the instuctions or creating/burning the VCD, but when i come to play back the VCD the player in disc mode refuses to play past the opening menu page.
I'm thinking that it's something i've missed in either Nero options/set-up, or the same with Power DVD or there are issues with some playback software not recognising menus!
I'd appreciate any help i can get.
Andy
"refusses to play past the opening menu" you meant even after you select menu number (1,2,3..) and depress [OK] or [Play] button?
Thanks whomever you are for that observation, it hadn't occured to me that there should be a number pad on my playback software, the default skin (Sony realist) didn't have one!
I've been burning videos without any extras, menus and so on, the VCD's i'd burnt played straight through when in play back, so i guess i was expecting the same result almost like an opening page.
Anyway cheers
menus with VIDEO_TS playback in VLC possible?
By wcndave in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 10:37 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 22:51 -
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 17:25 -
Menus on DL-DVDs created with DVDShrink...
By takearushfan in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 02:48 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46
