is there a way to skip the file check in nero 5 ? it takes so long and i know my files are compliant.
Yes, on Nero soft unable/disable box ISO-compliant option. But only if you are sure that your files are compliant.
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 19:29 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
HDMI compliant?
By vanjo in forum DVB / IPTVReplies: 6Last Post: 16th Oct 2007, 20:47 -
Blank Check Command Error In Nero????
By steveuk200 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2007, 02:31
