I have mp3 music I want to use for background music, some WAV files that I want to use, and an .AC3 sound file I again want to use.
Maestro won't let me import any of them. the AC3 was encoded using Sonic Soft Encode, and WAV file was converted from mp3 and the mp3 just plain won't work. How can I get Maestro to accept them ?
Also, is there any way for me to import the AC3 file without losing the Dolby Digital encoding??
Maestro accepts AC3 2 ch up to 5:1 (you could do mono also i guess) and DTS and PCM .. there is a bit rate max and the audio MUST be in 48khz sample rate. Maestro also PCM audio (wav) - again it must be 48khz ..
When you purchase a Maestro system - you are generaly given training on this. But none the less.
so wav files convert to 48khz 16bit , mp3 convert to wav same settings.
ussually 33- 67ms delay of audio - dont run the audio past the video (well you can but some players dont like it)
DVD to WAV/MP3
By Baldrick in forum AudioReplies: 38Last Post: 10th Oct 2020, 03:47 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12 -
Mixing AC3 and WAV on a DVD
By SCDVD in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2007, 00:33
