Hi.
I downloaded Angel Eyes and while I´m looking in my DivX-player it´s fine, but when I try to open it in TMPGEnc the sound dissapear.
Why?
Thanks anyone
Stefan
First off make sure you have the right codecs for divx including sound and make sure there installed right. Second, make sure you have the TMPGEnc divx add on. It allows you to convert them and more importantly open them on it. Second what settings are you using? Or are you just using the wizard?
More details..."...a devil from paradise, or maybe an angel from hell..." ~Faye Valentine~ -
Hi.
I have install the program and no extra patches.
It works great with a lot of other divX files.
I dont have any extra soundfile to any of the other files I have decoded.
I can see the "soundbar" for other movies, but on this one its just a plain green line.
I use the default settings except for the size of the outputfile (pal-center on screen and keep aspect ratio).
Where can I find TMPGEnc divx add on?
Stefan
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
DivX audio Q
By Tafflad in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2011, 12:13 -
No audio on divx file
By didikai in forum AudioReplies: 5Last Post: 30th May 2010, 09:33 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
no audio on some divx files
By philquad in forum AudioReplies: 6Last Post: 1st Dec 2007, 23:16
