I want a sound file that was intended for 25 fps to be multiplexed with a 23,976 fps movie without the sound going out of sync, how can I do this??
"After every storm, if you look hard enough a rainbow appears", Mariah Carey
Extract your sound file as wav then remux it to the 23.97 fps file.
I'm assuming both the 25fps & 23.97fps movies have the same exact running times. As long as the wav file and the 23.97fps file have the same running time, they should mux in sync. -
It sounds like extracting you audio is the only way to have audio sync. Is this true?
There may be other (maybe better) ways. This was just the method I would currently use.Originally Posted by rickki804
Sound out of sync in Avidemux
By Lambert in forum EditingReplies: 21Last Post: 19th May 2010, 01:59 -
Out Of Sync sound in mpeg2
By JN in forum Video ConversionReplies: 2Last Post: 20th Nov 2009, 04:52 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 11:19 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 20:15 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 10:31
