I am new to this. I have recently downloaded a DIVX movie from the net and would like to burn it to CD as VCD. What is the easiest way to do this. There are loads of programs on this site, but don't know what is best. I ahve tried to use various software, but with no joy.
All recommendations will be greatly recieved.
Originally Posted by PCBasher
Vdub, to check for bad frames, edit, cut etc and TMPGEnc to convert to mpeg 1. If all goes well this is very simple.
http://www.virtualdub.org/
http://www.tmpgenc.net/ -
yes convert with tmpenc (dload in tools) if you dont see a picture the youll need to cahange a setting , goto options>env settings> vfapi plugin>youll see direct show multi media right click and make it higher priority until it has a value of 4 that should let you convert and you should now see the video in the preview screen . if you have audio probs youll have to extract it and convert to audio see the how to guides for divx to vcd they help alot
RE : rsuave5
I get all sorts of error messages when I try to convert directing the audio and video through tmpenc. It works OK when I use another program to convert to .wav format. Does this reduce the audio quality??? -
the audio was prob mp3 -- converting to wav is fine and good idea .. as long as it will stay in sync ..
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/
When you save out the audio, you should be saving it as uncompressed at a frequency that is used on VCD's (44.1khz)
Vdub
Audio > Full processing mode
Audio > Conversion > 44.1Khz
SAVE WAV
That's now ready for TMPGEnc, the quality should remain about the same, there will be a slight improvement in the conversion speed.
Sometimes the audio in a DVD rip is AC3, if this is the case you need to use Vdub AC3
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Or from Kazaa
Burning MPG and DIVX to a DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2010, 21:12 -
Burning HD DivX video to a DVD
By HamishM in forum Authoring (DVD)Replies: 10Last Post: 21st May 2009, 09:35 -
burning divx file to dvd
By yesnikki in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2007, 04:37 -
Burning Divx movies with subtitles?
By Hank Kinsley in forum SubtitleReplies: 5Last Post: 17th Jul 2007, 11:33 -
divx burning?
By pbure0110 in forum Video ConversionReplies: 5Last Post: 29th Jun 2007, 14:17
