ive searhed the whole forum and i cant come up with a conslusive or direct answer if u can convert DTS audio to WAVE.. i know u can rip it with DVD2AVI 1.7.7.3 but thats about it what do i do next.. hope someone can help..
	Ok - so you have your DTS output in wav format - what do YOU want to do with it ! Do you wish to make a VCD and mux the WAV with an MPG ?
 If you don't tell us what you're trying to do we can't help you !
	well i tought what i wrote is clear.... anyways what i wanted to do is i just wanted to convert DTS to WAVE or any other audio format so i can use it for MPEG... it seems that there isnt any coz ive searched other sites too and there's clearly none yet so far... thx
	Just click on edit on your first post to change the subject.
	i dont think there is any easy way of doing it - you will have to record it in real time i guess as you play the file local... helps to have a good 6 channel sound card and a multitracker editor.
 http://www.minnetonkaaudio.com/SurCode_DVD_Pro_3.htm
 it will encode it and play back the file -- but not convert it back to wav.
  [Mkv To Avi] H265 and DTS | Can It be Converted?By konzine in forum Video ConversionReplies: 7Last Post: 9th May 2015, 12:37
  How i can convert the dts-es or dts-ex 6.1 into dts core 5.1By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25
  AVI with DTSBy bigjaykay78 in forum Video ConversionReplies: 14Last Post: 6th Jan 2011, 01:41
  help gettinng .m2ts with dts to play on ps3 with the dts intact. got closeBy jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10
  DTS encoded disk, output to DTS receiver using an HTPCBy ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
