I made a svcd that is 78 minutes long, My standalone only thinks it is 39 minutes long but does play the whole video, but the sound is choppy the entire way through the movie. Right now the sound is at a bitrate of 1150kbps. Any help would be greatly apperciated.
You have a VCD sound rate ?
Super Video-CD NTSC (MPEG-2 480x480 29.97fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
Super Video-CD PAL (MPEG-2 480x576 25fps CBR 2520kbps, Layer-2 44100Hz 224kbps)
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps) -
KingJohn,
I am having a similar problem. I am using DVDx to output an MPEG for SVCD. The finished MPEG would not play on Windows Media Player (error: could not find a suitable decompressor). But I can take the MPEG in VCDEsay and burn the SVCD.
The video on the SVCD plays fine, but sound is choppy and out of synch.
Looking at your message, the highest audio bitrate on the output setting of DVDx is 384. Where do I go to set the 2520 kbps you mentioned in your message?
Kevin
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 19:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 04:51 -
Chipmunk-sound-like problem...
By aruwin in forum Video ConversionReplies: 3Last Post: 28th Nov 2007, 04:34 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 07:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 21:22
