Is it possible to split a dvd that has been ripped with smartripper then edited ifo edit to contain just the main movie. I want just the movie on both dvds no menus. All help is appreciated.
here u go ...check this link
http://mpucoder.kewlhair.com/derrow/splitdvd.html
have fun splitting -
O.K. I'M not sure if this is what you want but for just splitting movies that are 2 big for 1 dvd i.e.(BLACK HAWK DOWN) do everything the same as normal in ifoedit then just drag half the VOB's out of the folder and just put them on the desktop then burn folder then rename vob's on desktop to match the ones you had in the folder so if you had 1-6 and took out 4-5-6 rename these to 1-2-3 then burn 2 other side of disc or 2 the second disc if just using single sided.
Hope this helps....
GARGOYL...
HAPPINESS IS RENTING A 4.3 GB. MOVIE...
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 02:13 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 04:37 -
Which files are the main movie
By RemainsHuman01 in forum Authoring (DVD)Replies: 1Last Post: 7th Aug 2008, 15:38 -
Main Movie has no sound
By Keesfan in forum DVD RippingReplies: 11Last Post: 1st Sep 2007, 00:32
