I tried to use dvd2avi but I could not create an AVI file. Also if this possible to get it into AVI file, I want to use DVD workshop or pinnancle express to take the AVI and let it do the magic to encode and burn for me to get it on a DVD.
let me get this right - you want to take a dvd , convert it to avi , and then encode it BACK to mpeg2 and burn it again on dvd ?
why not just rip the dvd and and re-author it and burn it back on dvd ? or a bunch of other ways published here on copy dvd to dvd-r -
I am having touble after the rip stuff. I am just lazzy, when I capture to my hd to AVI file from my capture card. I then take the avi file and put into express to encode and burn. After about 24 hours I am done.
If you can give me another suguestions I would appreciate it. I was using smartripper then DVD2AVI ....
I am trying to do American Pie the collectors edition 95 minutes long if anybody has done it can you give me help I am a newbie. -
Let's see... converting a 95 minute film to AVI will be 95min x 24fps x 1MB/frame ~ 137MEGABYTES of needed storage. Also, you better set aside about a week for the encoding process.
Yes, I agree with you... you are lazy. Try being a little "less" lazy and reading the guides here. They will "guide" you through the process to your desired goal.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 20:21
