I burnt some one minute samples as CVD with following profiles and amazingly they all play on my SUPER DVD-903. Only slight blocks are noticed on the samples below 700. Also the actor's head seems to twitch which might have to do with my burning too fast (4x)
The player LCD SCREEN detects & displays SVCD and starts playing. I can fast forward up to 4x speed with no problem.
RES= 352 X 480, CONSTANT zero quality (ENCODED BY TmpeEng)
Clip file size based on one minute burned on a 700m capacity CD with Nero at 4x
CLIP 1) 600 MIN /2520 MAX = 6167 kb
CLIP 2) 700 MIN /2520 MAX = 6933 kb
CLIP 3) 800 MIN /2520 MAX = 7671 kb
CLIP 4) 900 MIN /2520 MAX = 8357 kb
CLIP 5) 1000 MIN /2520 MAX = 9169 kb
CONSTANT yields the least file size, Quality at zero to 25 yields same file size. When setting is slided to 50, file size starts to move upwards.
The next lowest size yielders are VBR automatic and VBR MANUAL. Then 2 pass almost doubles.
I have some 120 minute length movie to encode, in order to fit on one cd, I figure that I must squeeze some 5888 kb in a minute which I am going to try. Or I can leave it at that and use a 800 m CD which I dont know if my player will accept.
Filesize is dependant on bitrate. 2-pass vbr, automatic vbr...these do not result in larger filesizes you are simply allowing them to use more bitrate. With 2-pass vbr you can calculate the avg bitrate to use so you can make it any filesize you want.
Most dvd players have no problem playing bitrates that low, the problem is that at those bitrates the quality is pretty poor.
Getting top quality Kbps from streams using variable bitrate screen control
By jilly in forum Video Streaming DownloadingReplies: 7Last Post: 1st May 2014, 16:42 -
How can we know if a DVD player accepts IDX/Sub file?
By user2008 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 22nd Dec 2009, 11:13 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 19:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
How low can I make xvid bitrate and still play on new DVD player?
By jimdagys in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 22:07
