i heard that a divx can have subtitles how can i find them,i saw that there should be another file with the divx file but i have only downloaded the divx file nothing more.Does that mean that there r no subtitles?
and am i able to add one myselff?
thxn4all
Robbert
It never rainz but it poors!
Some DivX (particularly if you get them from usenet) come with subtitle files. There are also sites which apparently provide them for download, but I have not tried them. If you are doing your own DVD rips, then it is a simple matter to include the various subtitle files. Vobsub is a very good program for this. There are others that may be even better.
i download with direct connect.Without subtitles files just movie.avi.Where can i find subtitle files
thnx4all
RobbertIt never rainz but it poors! -
I don't know of the urls but they do exist. The only subtitlles I have had direct experience of are the ones I extracted from DVD myself. Maybe someone else knows of some sites?
Here are some links I just turned up, but I have not checked them out:
http://dvd.box.sk/
http://www.geocities.com/divxplayer/usefulstuff/subtitlefiles.html
http://www.ultimateresourcesite.com/divx/main.htm -
this is the url that i use for download subs:
***link deleted by truman***
For subtitles you should go to:
There you have some links to some good subtitles pages (some need subscription, but they're free).
After you have the subtitle file you will need some player that alouds subtitles, like BSPlayer (www.bsplayer.org).
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
