I am trying to help a friend figure out what's causing TMPGEnc to go to a black screen at around 50% during encoding. All is fine up to that point . The encoding process continues to work but the preview screen just goes dark. She checked the final MPG file and sure enough it goes dark as well so it is actually happening in the final output as well. I have looked around here as well the FAQ on the TMPGEnc site but haven't came up with anything. Any ideas?
Thanks..
Rick
Results 1 to 10 of 10
One other thing I meant to mention was that she has tried 3 different files and they all do the same thing..
mm, well install the "Nimo codec pack anyway". Use Vdub to scan for junk frames, maybe there are some at 50% into the movie.
Vdub > Scan video stream for errors
Video > direct stream copy
Audio > Direct stream copy
SAVE AVI
Save as Movie2.avi
TMPGEnc
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
Load VCD template
START -
it is normal for the screen to go black for half the encode, this is when its doing the first pass normally when doing a 2 pass encode
Happens to me as well, only on 1 occassion though! I tried to repaet a few times, and it suddetly come good!
Try setting the source range. If you're doing Divx and not setting the source range than that might be the problem.
Ah, when you said 50%, I thought you were talking about half way through the movie.Originally Posted by MrE 15
The first pass will be black -
He/she didnt say anything about about 2 pass VBR...he/she said it goes black after the 50% mark when encoding. In 2 Pass, the first 50% is black, which everyone knows!
So you think everybody knows do you ? Think again !Originally Posted by Wicked_Al
touche!
But I believe this is just a source range problem. Selecting the full movie as the source range should make it stop. One way to tell would be to use the preview and see when the movie stops. This happens to me with some divx files....not sure why, but the source range usually takes care of it.
mark 9-20-10 on your calenders...
By deadrats in forum Video ConversionReplies: 2Last Post: 18th Sep 2010, 02:46 -
Blacks are lightened with MKV2VOB
By ZiGGY909 in forum Media Center PC / MediaCentersReplies: 5Last Post: 20th Feb 2010, 19:36 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Highlighted Mark in Menu
By stecaro in forum DVD RippingReplies: 2Last Post: 22nd May 2009, 15:16 -
Players w/ mark-in, mark-out
By kippard in forum Software PlayingReplies: 0Last Post: 30th Dec 2007, 21:16
