Hi,
I have used CCE to convert some AVI's to MPEG2. Im trying to burn the mpegs onto DVD using the how to guide. When I use DVDPatcher, is says the bitrate is 6000000, the size is 512x384 and the frame rate is 23.976. The guide doesn't say what to patch the header to so I tried both settings, but I can't get SpruceUp to accept the patched file.
Anyone got any suggestions?
Cheers
Nasdaq
Burning to DVD? I don't think so with this motley lot. The DVD spec is very specific, and there is NO 512x384 video size. Also, there is no 23.976 frame rate.
If you are going to do this, do it right. Re-encode the original AVI with a resizeing filter it to bring the total size to 720x480 (or 576 if you are PAL). Be sure to turn on the CCE DVD COMPLIENT box. Then apply PULLDOWN to bring your 23.976 frame rate to 29.97 (but this is the NTSC standard).
Once this is done, Spruceup will love you (and your video!).
Strange Mpeg2 Conversion Question
By mohawkcr in forum Video ConversionReplies: 1Last Post: 5th May 2010, 21:34 -
File Size & Video Bitrate Calculator
By wiseant in forum Video ConversionReplies: 3Last Post: 27th Nov 2009, 22:59 -
mpeg2 bitrate conversion
By sandiegoguy in forum MacReplies: 6Last Post: 16th Aug 2009, 04:40 -
Conversion of MPEG2 files to smaller size
By tonyaldr in forum Video ConversionReplies: 13Last Post: 2nd Aug 2008, 22:43 -
MPEG2's @ 18,000 Bitrate - Need To Chop & Shuffle. Where To Begin?
By EViS in forum EditingReplies: 1Last Post: 17th May 2008, 12:43
