I have just dl stuart little 2 full film, plays alright through media player but when I try to encode with TMPGenc it gets to just over 50% and then stops . Anyone have advice
have you tried repaired the source
http://www.vcdhelp.com/faq.htm#fixdivx -
Did you already post this somewhere else ?Originally Posted by jondi
Your AVI has probable got junk frames, use Vdub
Vdub > Scan video stream for errors
Video > direct stream copy
Audio > Direct stream copy
SAVE AVI
Save as Movie2.avi
If the scan fails use "vdub-mp3-freeze.exe" which makes a log of them at c:\badframes.log which you can use to delete the highest first
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
New PC - Encodes not as good...
By Browncoat in forum Newbie / General discussionsReplies: 28Last Post: 17th Jan 2008, 17:39 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 08:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
