I recently dl a .avi file that had an annoying logo on the bottom portion of the screen. I used the "fill filter" in VirtualDub (quickest and best way to eliminate the logo in my experience), but when I save the new .avi, there seems to be a "wave" of purple blockiness that fades in and out. Wondering if there's a way around this
Have seen this if you have the SMR (Angel Portion) codec installed, un-install it.
Logo away is good at blocking out those logo's, or crop them out
Did you save as uncompressed video then ?, you never said if you selected any codec's.. -
I saved the avi file using the MS-MPEG4 V3 (same compression that file was originally in) I also installed all my codecs via Nimo....is SMR one of them in there? It also plays fine in Windows Media Player, without that stupid wave or Angel Potion...just when i fill and resave the avi
Stay Clean.
Stay Strong.
Stay Focused. -
SMR is not part of Nimo, but people download movies with the word SMR in its name, and then install the SMR codec.
Ok on the codec, I would think you would also need the DirecShow hack, Nimo gives that also. As M$ don't want people to use V3 for AVI only ASF, then when people do use it, Media player refuses to play it
but that's not your problem as you can play.
However I would suggest you try a small save with another codec just incase... But check to see if SMR is on your system first -
Thanks for the help KingJohn...I ended up reinstalling NIMO and I read someplace that the Divx 4.12 Codec pack was linked to Angel Potion. I only installed the Divx 5.0 Codec pack via Nimo and everything seems to be peachy. Thanks again
Stay Clean.
Stay Strong.
Stay Focused. -
It is another version of MPEG-4 V3, however if you re-install Nimo, it may have overwritten it. Glad you got it to work anyway.
Converting YV12 to anything else causes inexplicable blockiness
By Asterra in forum Capturing and VCRReplies: 13Last Post: 19th Apr 2011, 07:02 -
m2ts to xvid or h264 always gets blockiness
By ubulord in forum Video ConversionReplies: 29Last Post: 24th Dec 2010, 13:18 -
Splitting & fading
By carlmart in forum AudioReplies: 32Last Post: 5th Oct 2009, 18:34 -
fading out last 50 frames - but no keyframe.
By davexnet in forum Video ConversionReplies: 3Last Post: 4th Feb 2009, 23:33 -
help with avs script (dv to mpeg2) Fading in/out
By ZiGGY909 in forum EditingReplies: 2Last Post: 14th Nov 2007, 15:12
