Hello,
i want to burn a VCD with easy cd creator. I have downloaded an VCD movie which exists of one file with the exstension: bin and one with the extension: cue. The bin file is the large file it is about 500 mb. What do i have to do to play it on my DVD player ? I know my DVD player is capable of playing VCD movies. Do i have to convert it to mpeg ? or rename it ?
Thanks alot for you're help !!!!
Greetings
Lau
Use CDRWin (or check your email cause I sent a longer explanation =)
can you please post or send me via email the directions too? thanks in advance!
another good program to burn bin/cue files is fireburner..
its pretty simple to use aswell..
http://www.fireburner.com
How to rip the video from (S)VCD CDs or BIN/CUE images
By Baldrick in forum User guidesReplies: 45Last Post: 4th Aug 2010, 05:56 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
