Looking to spend around $40 - $80....
Just bought a stupid i/o magic card from incompetinent (Comp) USA...
tech said it would have both a video output and input...turns out only records from tv (which I wanted to convert vcr tapes) and it doesn't output to a tv and it says it has a avi. to mpg converted...all were wrong
Here's what I'm looking for
1. Card that can output video to a TV.
2. Card that can record sat, dvd, or vcr.
3. Card that has software that can compress avi to mpg
I at least need something that can do 2 and 3
Also I tried that avi to mpg converted (the tp whatever & avivcd) and both take about 2 days to decode stuff then the only thing they encode is audio, I get no video and I've read your how to sections and didn't find anything on them....Help GREATLY appreciated![]()
The card you got is a basic BT8x8 card. If you have a fast PC, you can capture high quality video in AVI and then software compress to mpeg. If you have a slow PC with a small hard drive, forget it!
To jump over getting a fast powerfull PC with a 80 gig hard drive, you can get a hardware based mpeg compressor. The cheapest and best card is the Hauppauge WinTV PVR-250 for $150. It does not have a TV out, only inputs and for capture. It has a TV tuner, composite and S-video inputs. It will record VCD, SVCD and DVD mpeg compressed video in real-time.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
