  1. hey, everything is working, but i was wondering how i can speed up the encoding process without takin away from the picture..i noticed you can higher the priority of a few things, but i dont know which ones to raise? i wont be running anyother programs while encoding, i have a 1300 athlon and 256mb so im hopin for enough power...well hope you guys can help with this..thanks
    Jul 2001
    Brazil
    The priority on TMPGenc software feature is looking for the best quality encode as much as posible and not speed. Bios & Control Panel settings(DMA) and settings on TMPGenc(higher to priority of a few things as you said) all is important and help.
  3. im not really sure what your sayin, do you mean there is really no way to speed it up at all then? i understand what your sayin about quality not speed, but i dont know what you mean for sure..
