what software do i need to convert avi movies to vcd or playable on my home dvd player, anything would be really helpfull Thanks from dumb newbie
Very good "How To..." guides over this way:
<-----------------------As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
First you will need Vdub, you can use this to edit, cut and check for bad frames, you can also use it to save out the audio if necessary.Originally Posted by pancho
http://www.virtualdub.org/
When the AVI is OK, you can then use TMPGEnc to convert it to a mpeg 1, by loading a VCD template (PAL or NTSC)
http://www.tmpgenc.net/
Finally you will need some authoring software that will make VCD's like Nero, Easy CD creator, Video pack 5 etc
is there a simple way to convert an avi to vcd?
By lks9042 in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2009, 04:00 -
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 16:19 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
