    Aug 2002
    Germany
    I know, normaly they all want it the other way. But me, I prefer for my collection DIVX CD's (means "1CD per movie").
    So, now my problem is, that I never arrived converting a SVCD movie to divx without a much smaler picture or broken sound.
    Is there a way for a good and easy conversion?
    Thanx a lot in advance.
    christoph.g.r@gmx.de
    tried vidomi ? open the the mpg and encode and then join both.
    or try dvd2avi and open both mpg and crop,resize and encode
  3. Banned
    Jun 2001
    UK
    TMPGEnc > File > Output to file > AVI
    You can also select a codec
    You may need a mpeg 2 codec, if using the free TMPGEnc then Nimo codec pack is fine, else install Power DVD 4 for TMPGEnc Plus 2.57
    Aug 2002
    Germany
    @Baldrick
    Vidomi works fine, thanx.
    But the size of the movie is too small as Divx.
    Can you modify this in any way???
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    yes you can modify the size. you should be able to config how big the file should be in vidomi.
    Aug 2002
    Germany
    @ Baldrick
    Well, yes you can.
    But only the maximum size.
    I entered 800 MB but the films all got a size of around 500 MB.
    So in fact the size of the window is small...too small.
    It's a big loss in quality...
    Is there a way?
