I have a home network with ethernet/hpna.
My host pc (with NIC and HPNA cards) has a cable modem and a 2wire gateway/router attached.
I want to share files with friends in a channel in mirc.I can receive files from the F Server of others but they cannot get anything from me. i set up a F Server but cannot send anything to others either thru F server or DCC send.
I enabled mirc in my zonealarm settings and also in my 2wire gateway settings , i entered mirc as a application service host with port 6667.
i played around with the settings in DCC options several times but so far i cannot serve or dcc send in mirc.
Any ideas ?
I still feel it could be something in my 2wire gateway/router but could not find anything on 2wire website
With some of those routers, You simply cannot do what you want to do.
Some of them allow you to place a computer outside of the firewall Demilitarized Zone (DMZ)
Virtual Server's are only for computers that run a server like Apache on port 80
Special Application Settings, are what you have been setting with those port numbers, have you entered a range or just one port?
I don’t have those problems, I use a Belkin 4 port
Have you contacted them with your problem ?
TSA not only copying but sharing your computer files
By deadrats in forum Off topicReplies: 1Last Post: 20th Jan 2010, 21:33 -
Internet Thumbnail Problem - Comodo Firewall Help?
By hech54 in forum ComputerReplies: 1Last Post: 4th Jan 2010, 05:17 -
Problem with sharing a video to different formats with Premiere Elements
By coriscow in forum EditingReplies: 1Last Post: 17th Dec 2009, 23:36 -
OT: Sharing files
By danielmak in forum MacReplies: 3Last Post: 26th Aug 2008, 21:44 -
Comodo Firewall Pro - Free firewall
By bluemoss in forum ComputerReplies: 7Last Post: 10th Nov 2007, 09:44
