I have successfully burned MPEG files to a CD (usiing EZ CD 5.0 and Iomega 650 burner). They will play on my computer, but they will not play on my DVD player (Panasonic A110 says it is VCD compatible). I'm looking at a lot of other messages here and a lot of people seem to have the same problem. Are there any good solutions? Is it the CD-R's themselves? Colors, layers, etc? Things I know nothing about. Any suggestions out there?
id you burn as a vcd or just data(video), when you burnt it as data you're dvd wil not play but most off the dvd players can play vcd you have to burn it that way
The problem is your DVD player! It will not read CDR/CD-RWs. I owned a Panasonic A100 and that wouldn't play them either, it even said in the manual NOT to attempt to play them as it my cause damage! Just because a player is VCD compatible it does NOT mean it will play CDR/RWs. In fact I think that ALL DVD players play commercial VCDs it's part of the DVD standard.
<font size=-1>[ This Message was edited by: mh2360 on 2001-08-10 12:29:32 ]</font>
<font size=-1>[ This Message was edited by: mh2360 on 2001-08-10 13:07:41 ]</font> -
OK. I guess I do not know. Using CD Creator, I burned an mpeg which has an .dat extension on the CD. Is that data or VCD format? If it is not VCD, how do I get it into VCD format before I burn it?
After a successful DVD hack CD function does not play
By rexas_texas in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd May 2009, 09:49 -
Successful HD recording of Transport Stream.
By onerogueman in forum DVB / IPTVReplies: 0Last Post: 23rd Apr 2009, 21:06 -
Any successful blu ray burns?
By tchambers in forum Authoring (Blu-ray)Replies: 8Last Post: 3rd Mar 2008, 14:39 -
How to verify a successful encode
By maxxed in forum Newbie / General discussionsReplies: 6Last Post: 8th Feb 2008, 21:31 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 20:53
