Hi,
I wanted to add some splash screens to the start and end of some videos I downloaded, but after re-encoding, I found that the end file is not as 'crisp' and not the same quality as the original... would it be the software I'm using, or maybe its the hardware I have?
I'm using Ulead Media Studio 6 to add the splash screens and then it re-encodes the whole file.
Also, I'm re-encoding at the same resolution and bitrate.
One more point, I have a video file that is 90MB, but after re-encoding at the same resolution and bitrate its around 45MB instead, but the quality is a little worse. And this is the same when I take an 45MB file and re-encode it, its still 45MB but as I said, quality is not up there with the original.... What software should I be using, and what is a good PAL resolution and bitrate? Its all Mpeg-1 BTW.
Thanks in advance.
Results 1 to 10 of 10
MPEG is a lossy format. Every time you re-encode an MPEG file, it will get slightly worse.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Ok... so do you have any suggestions as to how I can add splash screens without loss of quality?Originally Posted by Mirror_Image
Thanks. -
Instead of re-encoding the entire clip, just add the start and end splash screen clips as separate files - for example, if you use VCDEasy, you can specify the delay between segments; just set it zero.
Will there be 3 files then? Also, can you do transition effects with VCDEasy?Originally Posted by Gargoyle
Thanks. -
Also, if you have the option to use your file to set the specs of your project, ("Set specs same as a file I specify", at which point you specify your main file), then (if it's anything like VideoStudio) it won't re-encode the entire file, just the frames that are affected by the transitions and titles. The other frames will just be re-muxed, but not re-encoded.
My previous post referred to Ulead Media Studio (which I failed to specify).
For some reason I can't seem to find that option anywhere. Are you talking about Media Studio Pro 6.0?Originally Posted by Mirror_Image
Low File Size yet retains the original quality. How?
By NeroLi8gerzid in forum Video ConversionReplies: 8Last Post: 6th Oct 2011, 18:46 -
Editing a MTS Files and keeping the original quality?
By PHNeedsHelp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 19th Feb 2011, 13:38 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
BD to DVD-9 - how do I keep original sound and get best video quality?
By rilopes in forum Blu-ray RippingReplies: 2Last Post: 3rd Nov 2010, 05:05 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18
