I have a few VCDs that have an annoying beeping throughout the entire play of the disc. These mpeg files do NOT have beeping on them when I play them on my computer...only when burned to disc. I have tried using four different brands of cdr, and it still plagues me. Any ideas?
Hi,
I had the same problem,what i did was use tmpgenc go to file select mpeg tools,then select merge&cut add your mpeg files and merge them.even if it is only one big mpeg file that you have run it thriugh this and it should help. It works great for me.
Hope this helps
GOTSent, after conversion it leaves my .mp4's useless due to LOUD BEEPING
By Clifurd in forum Video ConversionReplies: 13Last Post: 16th Sep 2009, 05:01 -
Computer shut ByItself, Surge Protector Beeping
By kerrex_2006 in forum ComputerReplies: 3Last Post: 8th Apr 2009, 03:23 -
Capturing SWF Stream, Results in Taunting Server Admin Video
By smartwhois in forum Video Streaming DownloadingReplies: 1Last Post: 27th Jun 2008, 12:31 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
Beeping on audio on Panasonic HVX200
By spandau in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2007, 23:29
