Does anyone have any experience with getting codecs to run on virtual pc? Specifically, I'm having trouble with Divx 5. It crashes whenever I try to open the viewer, and the codec doesn't seem to be recognized by other programs. Is there a trick to getting it to work, or maybe an alternative that works on VPC? I did try the Nero pack with similar lack of success.
Thanks a lot.
Why are you trying to do this when Divx 5 runs fine just on your MAC ?
-S -
because I have a file that my mac doesn't want to decode and I want to try on the pc.
What type of file is it ? Media Pipe seems to be able to read almost anything.
-S -
It's an avi. My problem is not what will read though, it but what I can get running on Virtual PC. I can't seem to install codecs of ANY sort.
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 21:34 -
Help using CODECS
By karthikaravind in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2009, 03:06 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
