Hi All,
Just recently been getting Illegal MPEG Stream error! at the very end of every encode, apparently during the muxing of video & audio. Currentlly using TMPGEnc Plus v2.57.41.146. Did not get this on previous version of Plus. This problem would preclude of any usage on Batch mode, also have to go back and De-mux and Re-mux and this only works at times.
The intent here is to create and variable bitrate VideoCD with 23.976 fps. My TV sets will envoke the up-conversion to 29.97 upon play back.
Process:
DVDDecrypter - IFO Mode (Latest version)
DVD2AVI (1.86) - Forced Film; Save as Project to frame-serve to TMPGEnc, Audio as .wave
TMPGEnc Plus (2.57.41.146) - To Encode Video CD - Non Compliant Stream (Specified in Stream Type)
TMPGEnc Plus template overview:
352x240 MPEG1 - VideoCD
CQ_VBR: Max=1759 kbits/s ; Min=300 kbits/s ; CQ=55 ; Padding enabled
Aspect Ratio: 4:3 525 line (NTSC)
VB_Buffer Size: (0) Automatic
Motion Search: Normal
Audio: Default with exception of Bitrate, which is 128 kbits/s
Stream Type: MPEG-1 Video-CD (Non-standard)
Everything else is default per TMPGEnc Video-CD (NTSC_Film)
This always worked for me before, even in batch mode, but can't seem to drill down on the problem now.
Can anyone help?
				Results 1 to 1 of 1
  Problem converting from MPEG Program Stream to Transport StreamBy vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40
  TMPGEnc MTS to mpeg-4 problem/questionBy Justice37 in forum Video ConversionReplies: 0Last Post: 11th Aug 2010, 17:30
  No audio when saving .MPEG file from VOB stream using MPEG Streamclip?By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12
  Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40
  problem splitting mpeg with tmpgencBy jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
