I am a mac using, imac flat panel with superdrive. I also have Toast. Is there some way to use vcd format to store photographs that can be played on my dvd player.
There is only one direction...forward!
Yes! Click that "how to author" link on the left, then scroll to the bottom of the linked page.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks for the reply...I looked at the link and it appears to do it well, I have to use a $600 app (Clean 5), Virtual PC and TMPGEnc and a couple of other applications in the VPC environment. Is there not a way to get good results using Mac and system X and Toast?
Thanks,
There is only one direction...forward! -
the best way to author stills in a VCD is to use VCD Builder, an awesome OSX free app available on VersionTracker
Thanks, I have downloaded VCD builder: is the final product fairly hi res?
Also, I am using system 10.1.5. Lately, when I download a file (let's say from versiontracker), I get a .dmg file on my desk top which I convert to a file looking like a hard drives with the application in it. If I move that file to my hard drive to store it, an alias is then created in the drive rather than the app itself. So I must either left the application itself on my desktop or store the .dmg file as well. Is there a preference somewhere to change in disk copy or stuffit?? Very frustration...
Thanks, GJH
It supports VCD hi-res stills specs.. the result is awesome.Originally Posted by GJH
Press the ALT key while moving the file to avoid aliases and force copy.Originally Posted by GJH -
Thanks! Amazing...it took 7 minutes to get an answer to my post..
Awesome!
GJHThere is only one direction...forward! -
I have played with VCD builder and wonder...is there some way of previewing/playing your sequences before you burn and how can you make ie, type in a menu. It there a manual (beyond what was provided) for using VCD builder?? I intend once I figure it out, to start putting family archival pictures on cd or should I use DVD to do it?
Thanks,
Photo's on a DVD
By rockingham in forum Newbie / General discussionsReplies: 9Last Post: 29th Sep 2010, 00:17 -
Photo DVDs
By ingeborgdot in forum Authoring (DVD)Replies: 6Last Post: 30th Mar 2010, 13:06 -
Photo collage?
By foton in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2007, 05:29 -
Which program for Photo VCD?
By OS_Man in forum VCDEasy GeneralReplies: 1Last Post: 11th Jul 2007, 12:53 -
photo cd's
By backdrop001 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 18:02
