i have made many vcd off my current system primarily two parters but i tried the one disk method and had one success. now nothing seems to work. Created one disk vcd in vcd 2.0 format,"made mpeg with TMPGEnc" made bin/que with "vcdimager" fine, burn to disk with "cdwin" no errors, but when placed in dvd player it switches to vcd 1.1 format and shows blank screen as if nothing is on disk. has worked once with the "rookie" but can't seem to get it to work right now.
went back to guide and re-config tmpeg again now if freezes system up have to reboot and lose what has been convertedthought it might be corrupt file so scanned for errors with vdub, no found, joined another two files and will advise as to it out come
but can someone tell me why would it change formats? and what can i do to stop it doing so?
Results 1 to 1 of 1
Japanese VRO Disk problems
By HDBoxing in forum Software PlayingReplies: 15Last Post: 19th Dec 2010, 22:13 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Possible hard disk and computer problems..
By SE14man in forum ComputerReplies: 5Last Post: 18th Oct 2008, 18:10 -
Problems with Dual Layer disk burning.
By qaa in forum Newbie / General discussionsReplies: 19Last Post: 21st Apr 2008, 01:47 -
Vista and intel AHCI disk controller problems.
By ofbarea in forum ComputerReplies: 8Last Post: 20th Nov 2007, 20:36
