I have donwloaded this mpg to burn as vcd but it shows image tracing.
This happens throughout the whole movie, i thought i was drunk and had some double vision or something but it's like that
So the image just appears twice overlapping the other.
Is this ghost image?
Can i reencode the movie to get rid of it?
this is what MpegProperties 1.00 says:
Bitrate: 1.411 Mbit/sec
"stream id's in header: 1
video bound: 1
flags:
CSPS
audio lock
video lock
352x240
29,97 fps
video bitrate: 1.150 Mbit/sec
thx in advance![]()
Do not underestimate the power of stupid people in large groups
If you did not convert it yourself...i think you are out of luck...just a bad vcd... you can try to reencode, but it useually only gets worse...
If you did convert it yourself... did you do it right ? Perhaps use TMPGenc in VCD template. NERO does the conversion automatically when needed.
Most of the time, it'just a junk mpeg you got.
If it plays well on a pc or at a friend's it might be th edvd player. -
If you load it into one of the editors, do the frames look ghosted ? Vdub TMPGEnc ?
Do you have the right codec's ? Install the Nimo Codec pack
Do you have the wrong codec's ? Un-install the SMR (angel portion)
If you have Mpeg 2 (SVCD) you may also need to install a Mpeg 2 codec, Nimo has some, but the latest TMPGEnc Plus will only work with a few, Power DVD 4, will provide the correct one.
Also in TMPGEnc make sure the DirectShow priority is higher
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
Never seen what you refer to, but with the FAKE movies out there who knows what the idiots get up to, but I would think there is something wrong with your codec's.
TMPGEnc does have a filter to remove a ghost from an image
Question about restoring C drive from Ghost image
By jimdagys in forum ComputerReplies: 11Last Post: 24th Aug 2009, 14:24 -
DVD HDD with ghost image
By Belfour in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Apr 2009, 11:29 -
ghost
By huminity in forum ComputerReplies: 3Last Post: 12th Apr 2009, 11:03 -
Bootable ghost CD
By romanstopme in forum ComputerReplies: 4Last Post: 14th Nov 2008, 19:17 -
Restore Ghost Image Problem
By bevills1 in forum ComputerReplies: 3Last Post: 1st Apr 2008, 14:03
