  1. I downloaded a vcd and ended up with
    cd1.bin cd1.cue
    followed the instuctions on here on burning this with nero
    it worked fine, what a dodle thought I! hu
    downloaded the 2nd part had
    cd2.bin cd2.cue
    followed the exact same instuctions on burning with nero, and feeling quite
    confident, when i point nero towrds the cue file, it says that it can't open the cue file and
    ! m.r.kickass.cd2.›ã: The file "m.r.kickass.cd2.¢p" header is corrupt
    ! m.r.kickass.cd2.
    }±: The file "m.r.kickass.cd2.
    }¦" header is corrupt
    ! m.r.kickass.cd2.S¨: The file "m.r.kickass.cd2.S¤¿" header is corrupt
    help
    I will never learn
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    use cdrwin instead
  3. i also get the message in nero
    an error occured while loading the cue sheet file
    'c:\documents and settings\panv\desktop\movies\m.r.kickass.sc2.cue'
    (line 1).
    I will never learn
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    based on your second posted msg .. open cue file in notpad and edit the location of the bin file ... like it prob says "c://mylamerips/pron/new folder/xxxxxxxx.bin" <<<--- an example only
    change it to xxxxxxxx.bin only
  5. i'm not to familar with bin/cue files but i found out about this software or tool i actually found out about it on this site it's called daemon tools and it allows you to open the cue file in a virtual drive and use the cd copy method but i'm not sure if it will work in your case but you could try it i believe the link is www.daemon-tools.com if not try looking around in the tools section of the web site
  6. Thanks
    Managed to get it working
    deleted both the Bin and Cue files
    went back to the rar files in winrar and clicked on repair
    winrar told me that there were some suspect headers and would i like to extract them, i deleted these, extracted the rar files.
    ended up with Bin and Cue files this time they worked.
    now I have a movie on 2 cd's, next project try to fit it on to one CD,
    I came across something on this site about converting the dat file to mpeg!
    I will never learn
