Takes me 4 hrs to reencode a 5 gig file to 4.3 to burn onto DVD+R using rempeg. Any other programs faster with better quality??
Well thats pretty fast, I never used ReMPEG but I hear it's decent quality. Look into CCE (Cinemacraft Encoder), it may take longer than 4hrs (depending on your computer speed and RAM) but the quality will be top notch. TMPGEnc is a slow-poke but does a very nice job also. Search the forums for CCE information and also take a look at Doom9.net's forums for the same.
Cool..I have a AMD XP 2000+ with 512 Megs of DDR333. Rempeg isnt as much memory dependent as it is CPU. I definitely have the horsepower..just looking for the fastest and best quality. Thanks for the info...other suggestions would be great
that's really the only suggestion you need, CCE SP is fast (encodes in realtime) and it's hands down the best mpeg-2 encoder anywhere. use the doom9 guides for CCE-IFO edit http://www.doom9.org/mpg/ifoedit-cce.htm
well he is wanting mpeg-2 output, and while tmpegenc is great for mpeg-1 it's very sub-standard for mpeg-2 and it takes a God-awful long time to do it. but thanks for only saying tmpeg
Well I used DVD2SVCD using CCE 2.5SP, and whilst it isn't that quick on my machine (PIII 850Mhz), it does yield impressive results !
Panther
All say Grrrrrrrrrr...................... -
The thing I dont like about CCE is while encoding it slows your system to a stand still. While encoding w/ TMPG I can still use my system with to lag.
As far as TMPG being slow.....I have a Duron 1.2ghz w/ 512mb it takes about 9hrs. to do a 2-pass with a min of 300 and max of 2496. avg depends on the movie but always try for 2 disks. To me thats not really slow, I encode while at work or sleeping so its no big deal!!!!!
L8
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 10:40 -
the best video encoding app currently available?
By deadrats in forum Video ConversionReplies: 5Last Post: 15th Aug 2010, 17:47 -
Pictures Quality in which app?
By eliqush in forum EditingReplies: 3Last Post: 16th Sep 2009, 11:12 -
The best simple H264 Encoding App ?????
By Arlo in forum DVD RippingReplies: 3Last Post: 10th Dec 2008, 14:18 -
MISSING PROGRESS.APP hence the encoding doesnt continue
By drevinko in forum DVD RippingReplies: 1Last Post: 26th Feb 2008, 21:17
